- Nov 14, 2016
- 3,008
I have a set of lenses for a view camera ,
one 90mm
one 203mm
one 5 1/4 inch
not confusing at all
Don't forget that standard 1/4"-20 screw for tripod mounting your "35mm" camera (film what's that? ) .
one 90mm
one 203mm
one 5 1/4 inch
Google says the distance to the moon is: 238,900 mi, or 391,388 kilometers at the moment. 6 digits.... Lets see, if I understand 5 decimal places will get me to within ~10 miles of where I may need to be or is it even farther off. .... so get out the moon buggy. However, where in this conversation are the error bars? In this case 10 miles or so is good enough!? Yes, the proper way to do the conversion is to keep only as many decimal places as the original number.... 1.0 inches = 2.5cm, 1.00 inches is 2.54cm etc. Error bars are needed to know exactly what is meant. On the other hand if my mill has 0.007" of backlash why do I need to spec. a circular part to better than 0.001" . Certainly do not need to spec it at 0.0010. On the other hand, if I get a better mill..... some day....Five snorts is a quirt. Seven quirts is a fritz. And on and on. Any measure is relative to what is being done. I was reading a book on Railway Locomotives published 1911. Which indicates the information is from 1910 or earlier. In a section about machining replacement parts, a unit of measure of 1/64th was common. That the 1/64 was "scant" or "full" implies 1/128. That's actually pretty close to 2 tenths of a millimeter.
Today we think in thousandths, why not in tenths of a millimeter. Or we think in tenths of a millimeter. . . The question goes on and probably will for generations into the future. A grain of sand from Florida is considerably different than one from Tahiti, which is different than. . .
Precision math (actually arithmetic) has its' place. If I were building a rocket ship to go to the moon, I might want calculations to five decimal places. But for my home tinkering, two places full or scant is close enough.
Mathematics comes into play when one studies algebra (and trig, on my own) and better. Addition, subtraction, multiplication, and division don't reach that high. And "long division" is something we all do on a regular basis. In the time it takes to reach for a calculator, we have already determined that 1/16 inch equals 0.0625 inch. 1/256 takes a little longer, but why bother with a calculator. A pencil and paper is already handy if needed. And in reality, making a bolt from hex stock deserves a sketch anyway.
I didn't go to high school, barely finished grammar school. But I much prefer long hand pencil and paper for no other reason than batteries don't last forever. And usually die when most needed. I do have a (several) calculaters. To figure the secant of 24.5 degrees does take a bit of calculation. But to bisect that angle, the result is 12.25 degrees. That is basic arithmetic.
End of rant
I do mostly repair work and got tired of needing to get expensive metric fasteners. I now have sets from McMaster-Carr. If I only use 1/10th of them it is cheaper than the local outlets and saves me trips. It also allows me to design & work in metric for my own projects. Over time I've torn apart metric stuff and always saved the fasteners, now stored in plastic, labeled jars.Metric fasteners come in those little bins, wrapped in plastic, and usually at about four times the price.
That’s not a problem with the system of measurement. That’s a problem with incompetent/careless engineers at JPL.Tell that to the Mars Climate Orbiter team!
Mars Probe Lost Due to Simple Math Error
NASA lost its $125-million Mars Climate Orbiter because spacecraft engineers failed to convert from English to metric measurements when exchanging vital data before the craft was launched, space agency officials said Thursday.www.latimes.com
Robert
Unfortunately, I don't have enough call for metric fasteners to justify purchasing in bulk. I also save all fasteners, both metric and SAE from old machinery and equipment and I have a small stash. Most recently, I scrapped out about 6 tons of iron and pulled all the fasteners out. The cost of each fastener doesn't justify the effort by itself but when you factor in the 50 mile round trip and the 2 hours spent to get the fastener you need to finish a project, it makes sense.I do mostly repair work and got tired of needing to get expensive metric fasteners. I now have sets from McMaster-Carr. If I only use 1/10th of them it is cheaper than the local outlets and saves me trips. It also allows me to design & work in metric for my own projects. Over time I've torn apart metric stuff and always saved the fasteners, now stored in plastic, labeled jars.
