- Feb 19, 2014
- 112
Good morning all. After many many years of wanting a Bridgeport I’m finally getting one and I have a few questions about vfds that I couldn’t find an answer to searching on here.
So, I’ve never actually run a Bridgeport yet so excuse what I’m saying if it’s a little off. When I was looking at the machine the owner was showing me how when you put it in the different speeds you have to run the motor in reverse. Now from what I’ve read all speed control will be done from the vfd? Reversing also? Is there an optimal setting I should leave the belt on? Apologies for the newbie questions. I bought a TECO/Westinghouse 1hp vfd if that helps.
Question 2...the machine is three phase (obviously) and it has an X power feed that is also run off a separate three phase motor. Is there a way to run both the main motor and the power feed motor off the single vfd? Will the speed control also affect the power feed motor or is there a way to somehow not have the speed control not impact the power feed? Or should i replace the motor? This is my first time ever using a vfd.
Also for what it’s worth I don’t have the machine yet.
