Need some advise on this.
The left half of this cut is conventional milling and the surface finish is not great.
The right half is climb milled and beautiful.
Both .030 depth with same feed and speed. Whats going on?
Aluminum 6061. No fluids.
Im pretty sure I have my terms right. Climb milling as if the cutter was climbing the work piece or rolling across it like a tire would a road. Conventional as if it was scooping material out in front of it.
I tried both cuts twice with the same result before I made this example and even slowed my hand feed down to see if that affected anything.
