- Apr 14, 2014
- 3,163
Projectnut-When you made your coupling does it but up against the roller bearing?I just measure length for my coupling it looks like it needs to be 3” long to butt against roller bearing.One I have is to short if this is case,so another project I guess
No. My coupling sits tight against the threads on the lead screw and leaves about 1/4" of the shaft showing between it and the back of the plate the power feed is attached to. The coupling I replaced was 2 1/4" long and would rub against the back of the mounting plate. I don't see any need to extend the coupling through the plate to the bearing.
