- Nov 26, 2015
- 4,785
So a little back story. I got this "free" box fan from a buddy that was closing his welding shop. He said it worked but would shut off then come back on. So I had it on the bottom of my to do list "fix fan". Well recently I received a catalog from Surplus Center. In it was a large selection of motors. I thought now would be a good time to fix the fan. So I go out and check the tag on the fan motor to see what I have and need to order. Well the tag says 230 volts. The fan has a 110 plug on it. No wonder it did not want to run. So I ordered a 110 motor.
Well it arrives and the body of it is larger than the one I am replacing and also the external cap hump is in a different place. So the mounting system wont work with my new motor. No problem I will just fab something up.
So I machine a face plate for the new motor to mount against and a bottom support. Get everything welded up and painted. Install new motor and fan blade and it works great. Well only for like 5 minutes and it shuts off. I feel the motor and its extremely hot. Hmm what gives? I remove the motor once it cools and double check my wiring. I then plug it in and let it run on the bench. It runs for 15 minutes just fine and the motor is bearly over room temp. So after some contemplating I think the fan blade is too much for the motor shaft and is stressing it to the point that the temp raises and then the thermo protector kicks it off.
So Lets try this again. So I figured mount the fan on a shaft driven by a pulley and belt set up. That way the stress on the shaft motor is reduced and should spin fine. So I grabbed a chunk of mystery steel and made a collar sleeve. Pressed in bearings at both ends and pressed a shaft through. Before I pressed in the shaft
I milled screw flats on both ends. So here is where I am at now.
I need to fab an adjustable mount for either the motor or sleeve. I haven't decided yet.
So this "free" has cost me over 100 bucks so far. Not to mention all the time I have in it.
