- Apr 29, 2019
- 2,063
Check things over on the lathe in general, I also notice chatter on the chamfer at the end of the threads. Maybe something on the machine is loose.
Once you have the chatter you need to go back in super slow so that the reamer is only able to cut the tops of the chatter off. The issue with the floating reamer is that while the cutting edges are over the valleys of the chatter the reamer can move forward and back and even sideways since it is no longer held tight on the point of the center. The wrench can also put a side load on the reamer causing a deflection.
