- Dec 6, 2012
- 2,677
Another option with greater flexibility than a single reamer, and far less expensive than a boring head, is to make or purchase a single point cutter (fly cutter).
While not nearly as easy to use/accurate as a boring head or reamer. With enough fiddling you can get the results you want.
Additionally, the have can be used in a mill (surfacing). Please don't mill in a drill press.
Please be very careful about choosing an appropriate RPM and grinding the cutting tool with appropriate clearance.
But, as Terry has appropriately pointed out it may not work well in every DP depending on rigidity and runout.
There are many free plans on the internet. Or used shop made ones can be picked up cheap.
Daryl
MN
Daryl
MN
