- Oct 29, 2012
- 1,387
Yeah, with a press and die. Not sure why you would want to remove brass in a lathe. A press and die shoves the metal back to where it's supposed to be rather than cutting it off, which would result in a weaker case.There may be a better way to size necks?
Maybe he's changing the caliber of the brass (ex: turning 9mm cases into 380)? That's the only reason I can see for removing metal, but wouldn't explain the setup being discussed.
