Bolo Tie Slide
Fabrickator
Active Member
Jan 22, 2014
522
Likes
358
#1
I was playing on my new compound angle plate the other day and came up with a cool piece that I made into a Bolo Tie Slide. The main, mild, long "ramps" were made with the angle plate set at 5* and cut with a 1 1/2" end mill on the rotary table. For the steeper "point tip" back-cut angles I added 10* on the compound angle and used the RT. Then, I machined the center on the lathe to accommodate an inlay piece of nice, fiery Abalone Shell I found on the inter web. I picked up the braided leather cord, cord tips and clamp piece at the local Tandy Leather shop for another few bucks. After polishing it, I used a jewelry epoxy glue (HF) to put it all together. It's really flashy in different lighting with greens, blue and pinks. Cost me less than $25 to make.
Rick
G0602 Lathe
LMS Mini mill w/ RT & compound angle plate
RJSakowski
H-M Supporter - Premium Member
H-M Supporter-Premium Member
Feb 1, 2015
2,763
Likes
2,828
#2
Rick, you really do some neat stuff! What metal did you use?
Fabrickator
Active Member
Jan 22, 2014
522
Likes
358
#3
Thanks. I just used some 6061 aluminum I had around. Funny, when polished, and at a glance-it almost looks like sterling silver and Abalone looks like Opal to the novice eye.
Groundhog
Jan 20, 2016
500
Likes
593
#4
Very nice. I really like the design.
And the way you made it is pretty neat too!
Desolus
Apr 27, 2017
117
Likes
72
#5
This gives me an idea, although I think I'll cut mine in a dense foam and cast it in PM. I have a piece of ammolite I have been looking for something to do with and a bolo seems to be the perfect fit.
Container Above bottom breadcrumb
