- Feb 7, 2013
- 2,496
The bucket cylinder became droopy all of a sudden so had to find a way to take it apart and have a look at the inner workings.
The aluminum end cap on the cylinder has two quarter inch diameter holes for disassembly but one needs a specialized
tool to remove it. I made up an adjustable tool with 1/4 inch pins and it worked very well for the job. As it turned out the
nut that holds the piston has come loose causing the problem. Not having a 42 mm socket, I tightened the nut with a
hammer and a punch without doing much damage to the nut. I will have to disassemble the cylinder once I get the correct
socket and tighten it properly. For now, it is working just fine. I suppose it would be prudent to install the new ring and seal
kit while it is apart.
Here are several photos of the tool and one of the end of the bucket cylinder.
The pins were made of 1/4 inch diameter material, some pretty hard stuff...
