- Jan 1, 2018
- 1,163
A radial arm saw has to be properly aligned to run smoothly. Until you go through the alignment procedure and get it all dialed in I wouldn't even use it.
The usual advice for a radial arm saw blade is to get one with a negative rake. The tooth slants backwards instead of forwards which is supposed to keep the carriage from wanting to lurch forwards.
Unfortunately Craftsman radial arm saws aren't known for their heft or rigidity. The lite weight build makes them more more likely for the carriage to lurch forwards when making a cut and a positive rake blade enhances the problem. My first RAS was a Craftsman because it came with the fire damaged house I bought. It did the job but it never lived up to the 10" cast iron Delta turret arm RAS that I grew up learning woodworking on.
2.75 hp is the usual fantasy hp rating of the day. With a properly aligned saw and a good blade you should be able to make decently clean straight cuts. The low "real" hp of these saw makes them more likely to catch in a cut and cause safety problems. The Delta 10" turret arm RAS I grew up with was rated at 3/4 hp and it felt pretty equivalent to the Craftsman RAS I had.
I dumped the Craftsman saw 35 years ago when I picked up my 7.5 hp 3 phase 16" 1947 Redstar radial arm saw. The shear mass of the 7.5hp motor and carriage plus the incredible torque and rigidity has kept it from ever trying to lurch during a cut. Cutting with the Craftsman RAS is more restraining the carriage as it is pulling it forwards.
Properly ALIGN the Craftsman RAS!!!!! Buy a negative rake (same as a negative hook) blade. Keep an eye on Craigslist for a 10" or bigger Delta turret arm RAS. Many people like the cast iron Dewalt RAS's... I personally prefer the Deltas. I did get a lot of good use out of my Craftsman RAS before I turned into a complete radial arm saw.
