"Best" way to drill and coutnerbore for a 1/2-20 bolt?
LVLAaron
Oct 4, 2020
484
Working on this D1-5 backplate. I need to drill clearance holes and counterbore for the bolt head. For either 3/8-24 or 1/2-20 (haven't decided yet) machine bolts.
What's the "best" process for this? is this a two step op, clearance hole with one tool, counterbore with another? or is there a specific tool for the job? If not, what tool to drill the counterbore? HSS end mill?
Backplate is cast iron fwiw
I know they make counterbore tools for socket head screws. I would imagine there would be something for standard hex head if that's what you're after. I usually just use an end mill though.
Counterbore sets are readily available. I have no direct experience with these sets but here's a few listings:
https://www.amazon.com/Accusize-Ind...eywords=counterbore+set&qid=1647448087&sr=8-3
https://www.amazon.com/AccusizeTool...eywords=counterbore+set&qid=1647448087&sr=8-5
I like to do it in this order:
1) drill the guide hole for the counterbore pilot
2) do the counterbore to depth required
3) drill final thru-hole
Brian
Nice. That's what I figured. I found some USA made tools on MSC direct. Wish me luck!
My counterbores all have a pilot bushing the diameter of a standard clearance hole and cut a bore for a socket head cap screw. I am not aware of any that will cut a counterbore for a hex head cap screw.
Brian
Good advice! I guess I missed the part about counterboring for the (presumably) Allen capscrew.
Abomb79 uses center cutting end mills to counterbore his recessed cap-head screws.
But since you are working on D1-x fitment, you should use the D1-x threads.
But, also note: you should "index' the start of the thread so that after x turns each D1-x attachment is equally deep in its hole.
That is you want each thread to start at the same relative angle.
There is no such thing as a hex head cap screw. It's either a cap head screw or a hex head.
It's not common practice to counterbore for hex head screws as a spanner won't have access and no standard for square drive socket diameters.
