- Jun 22, 2023
- 384
what is the best material to use to make a gib, steel, brass, bronze?
and why?
and why?
why is that the best?Cast iron. Needs to be scraped flat and for oil retention.
Just because it is the best; cast iron rubbing against cast iron is the OEM best choice, hardened steel against cast iron is also good.why is that the best?
would a compound slide on a lathe be considered "low pressure"?Cast iron is the most common. They withstand pressure better than bronze. In precision tooling where sliding friction is a factor, then bronze gibbs are used. Bronze will last significantly longer in low pressure applications. If you use either, they have to be scraped and then flaked in order for them to give their longest service life.
[update] Sorry, @MyLilMule I missed your post before posting!
i will be using a 60deg dovetail mill so should be low pressure.Great question!
It all depends on the angle. If the compound is at less than 30 degrees (or even 35 degrees) from the perpendicular, then it is low pressure. But anything more, is rapidly growing in side pressure. e.g.
