Best 2022 Paint Stripper?
I had a big pot, and put the parts in the boiling water/tsp mix. Obviously it has to fit. for the bed of my lathe I power washed it.
But anything that went into the pot came out clean.
I had bought a cheap stainless big pot with cover from Wallyworld, and already had a roasting post big and oblong from my mom or somewhere.
was using it for parts cleaning..
brushing it on won't work. it needs to heat up the paint, and the tsp helps clean it at the same time. Just let it boil.
what do you do with the boiled paint goop?
I sift out the paint and throw it in the garbage, just a strainer.
The rest, I keep for the next operation. When I was all done, it was poured the water/tsp into the ground,
Interesting that you bring up lye. I used that to strip off the anodized finish from the stantions.
View attachment 392175They came out great after I polished them up on the lathe.
I have never tried oven cleaner as a paint remover. Does it work on oil based paint?
Yes, it attacks anything organic.
Oily nasty item needing stripped, toss it in bucket of lye and let it work.
Sent from my SM-G781V using Tapatalk
