- Oct 13, 2014
- 6,752
Hi All,
This is a system I came up with for securing small machines, tools etc. to a workbench top. Basically, it's a machine tool "slot & tee nut" arrangement, made out of common strut channel. It was a result of my commitment issues, except in this case instead of women, it was tool placement. The system allows items to be mounted securely and easily moved if needed. The machines are also mounted to strut channels and angle iron that allows them and the stock supports to slide out so longer pieces of work can be cut.
Construction: The base of the countertop is made out of 2 layers of ¾" plywood, the first layer is screwed to the cabinets below, then second layer was glued and screwed to the first layer, with staggered seams. The ½ height strut channels were screwed and Gorilla glued in between Formica laminated particleboard strips, that were glued down with white glue.
The admittedly ugly Formica was salvaged from 3 damaged sheets purchased at half price from The Home Depot, in hindsight I should have held out and ordered a more suitable pattern, but it was instantly available and cheap...
The total length is 26'
The ends of the channel are milled to allow the tee nuts to be inserted.
Polyurethane caulk at all seams. To prevent something like a spilled "large Coke to go" from wreaking havoc on the particleboard.
I used the same size bolt (⅜-16 spline drive) for most connections, so only one ⅜ box-end wrench is needed for most adjustments.
All the machine table heights are the same (6"above countertop) so they don't interfere with work from adjacent machines. this way, I can cut up to 6" wide and 10' long on any of the three saws without having to slide them out. So most metal stock can be cut easily and quickly.
The machines are very rigid even when extended out.
If I need to cut wider the chop saw can slide out and cut 16" wide X 12'+ right or left. If I ever need to cut longer, I can simply move the saw.
I also made all the "tee nuts", will post pics soon.
I plan on using this system to construct a welding table as well, stay tuned...
