- Apr 23, 2018
- 6,602
No, I haven't made one because I can get Deckel adapters off the shelf for $30 apiece. The Shars adapter won't work for you since it has an internal taper for the Deckel spindle, but that's the basic concept. You make a "hat" with a 1/2" bore for your grinder spindle on the inside and a 1-1/4" OD with threads for a nut. The nut has internal threads only. You cinch the nut onto the hat with the grinding wheel sandwiched between, then slip it over your grinder spindle. You can use internal threads on the 1/2" bore in place of a spindle nut, so the "hat" effectively replaces the spindle nut. Recessing the bore will have to be done to suit your grinder's spindle and nut configuration, but the basic idea is really easy. The arbor adapter could even be made of plastic or hardwood; it doesn't carry much load, since the load should be applied perpendicular to the spindle in theory.
