Yep, timing belts don't require as much tension. They also won't slip, that can be a good or bad thing. With a V belt it has the chance of slipping if a mishap were to occur & act like a clutch, well depending on how tight it is. May not save much & something most likely will get damaged but a timing belt does not have that chance. If the pulleys are slightly out of alignment the v belt self aligns. With a standard timing belt alignment is more of an issue. V belts are also cheaper & readily available. So if you ever needed a replacement belt in a hurry, a v belt could probably be found at the local auto parts or lawnmower shop. I don't really see the need or advantage of a timing belt in this case but either one is fine.
