- Jul 28, 2017
- 2,376
ABS probably would work better than aluminum, but not as good as HDPE or other similar abrasion-resistant plastics. If I had a choice I'd go with HDPE -- it's widely available. Something to think about: HDPE anti-friction tape, something you might find in a woodworking supply store. Stick it down on whatever you've got that's the right size. It can be fairly thick so would hold up awhile and is easy to renew when needed.Have never imagined that plastic will work ! I have a piece of ABS block collecting dust. Will it be good for the purpose ? ABS is known to be not very resistant to chemicals so I am wondering if stuffs in lapping compounds will attack it.
For your task at hand you don't need anything so refined but the knowledge on how to do it better can come in handy at times.
