- Oct 11, 2016
- 3,864
Sorry @Charlieman22 @sdelivery is right on. NEVER mix 3PH and 1ph circuits. In Canada, you are allowed to take a 1ph circuit off a 3PH panel using a 1pole breaker. If you have a 1ph panel you can never have a 3ph breaker in it. Strictly forbidden here, and I'm pretty sure it won't even fit. Get a pony box - a 3 phase box with no main breaker, and run your 3 phase circuit through it, with the correct sized 3ph breaker.
Everything should be done so in 5 years, you or then next owner can easily see what you did. Everything you do should pass code, even if you can skip the inspection.
