Bearing Press Fit Tolerance
I would suggest you contact the manufacturer of the bearings you intend to use. The fits matter because they impact on internal bearing clearances, which in turn impacts on longevity. You will need to bore accurately to obtain the proper fits. As mentioned, you meed to install them so that pressure is applied to the race only to avoid brinelling.
