- Nov 28, 2016
- 2,344
Back in the summer, I was replacing the floor pans in a 1964 Fairlane. I had bought repop pans, but they were very poor quality, so I decided to fabricate my own.
I ordered a Woodward Fab bead roller, but it was too flimsy to roll 18 ga mild steel without a lot of deflection, and very awkward to use with the hand crank.
I stripped the frame and welded stiffening gussets to the back to strengthen it.
Then I fabricated a stand to mount it on.
I replaced the crank with a sprocket and chain running to a gear reduction box that I had found at a yard sale. I attached a Harbor Freight drill to power it. The drill plugs into an outlet box on back of the stand. The outlet box plugs into a wall outlet, and is switched through a foot pedal.
I lock the trigger on the drill, and can use both hands to guide the sheet metal through the rollers. I can also reverse it with the drill....
It works pretty well... and the floor pans turned out pretty decent.
