- May 16, 2016
- 1,697
I've got a cheap Nikon camera that eats double As like pup-a-roni sticks. I take 'em out.
What gets me is when the device has an internal minimum voltage limit below which it won't run even if the batts still have some life left.
Argg.
I have one like that, Nikon Coolpix L22. Ate batteries, sometimes only a dozen or so pics and throw the batteries out, until I found it depends a lot on what batteries you use.
I found even the most expensive of the major brands rarely gave good life. The only ones that gave good life were the very expensive "camera " batteries Kodak and other brands, but generally only available in camera shops and very expensive.
Then one day in desperation I tried some rechargables Nimh type and found some worked and some didn't, Finally I got onto some enekeep by powertech 2000mAh. They worked really well and I have taken thousands of photos with these.
Recently I upgraded to eneloop by Panasonic 2100mAh and they are excellent. You will also need a suitable charger mine is from Powertech and will take 2 or 4 cells at a time AA or AAA full charge in 2 hours, and runs off 12v dc or mains power with a multi voltage power pack 100V to 250V, great for travelling.
Unfortunately I recently broke the little plastic lug that holds the battery door closed. So I'm experimenting with some epoxy goo to rebuild it. The little camera still takes great pics.
