- May 7, 2023
- 1,402
Don't disagree with any of your flex points. IMO, once you start the full cut it tends to pull all that flex and then continues the cut at the width of the cutter. The reason you want to cut the key in one pass full depth to get all that flex the same for the full pass. I had to recenter the 3/8" most likely because I centered the ¼" before taking a heavy cut. Once it cut the ¼" key it likely did shift over the backlash on the bed and I adjusted to that on the 3/8". No comparison of this machine to heavier or more rigid machines, just trying to help someone who asked see what it could do.
I get where you're coming from, but the round column machines have some unique issues that differ from other style machine issues.
Note I didn't say only "This or that" style machine has issues, they all have limitations. Knowing these will make your end result better and prevent tolerance stacking and such. I don't like using the term tolerance stacking as it has become a buzzword, but it does work nicely as a catchall.
I also have a round column mill and they have a unique issue in that they not only flex in all the normal places, but the column twists in reference to the head, sometimes winding up in a new location to your X/Y, and also laterally as well as deflecting, especially under heavy loads. First few times I used a round column it was a bit curious coming from learning on and using B-ports daily.
Your job has whatever needs it has, that have to be met, and if you are the end user or will be fitting the parts what you're doing is Ok.
If you plan on sending that part out to a customer, they may expect more.
Just food for thought.
