Bandsaw blade tension
I leave the tension on my shop saws, both wood and metal. But relieve it on the saw mill, it has a hydraulic tensioner. The blade runs with 1,200 pounds tension. If the temperature goes up the hydraulic fluid expands and the tension sky rockets.
Interestingly, when I first put a blade on the tension will drop for the first 4 or 5 cuts, keep bumping it up, then it holds steady. The blade must be stretching.
Greg
Or, perhaps it is heating up and lengthening
I too, have never released tension on the blades of any of the bandsaws that I have and do own, never a problem with tires.
“...how many times have people turned on the bandsaw before remembering to retention the blade?...”
I’m thinking probably quite a few, although maybe not more than once.
I have four of these flags hanging from a hot air duct in my shop. They’re just nylon tube webbing with a rare earth magnet stitched into one end. The tag of yellow makes them extra bright. On the odd occasion that I do have the tension down for some reason, on goes a flag. The next day, next hour, next month, whenever I want to use that machine again there is the flag telling “hey, check this first, dopey!”
Yes yes, I still have to remember to put the flag on but most of the time I do because I’m still in the moment of servicing the machine or whatever. It’s the next day, when I may be thinking of something else, that I’m liable to forget I was halfway through something.
Super easy to use, I find I use them on setups as well to say hey, don’t monkey with this setting, or hey, this clamp is slack for now. Might not work for everybody, but I like them.
-frank
That’s a great idea [mention]francist [/mention] similar to a lock out tag on a circuit breaker.
I actually patterned it after the flags they use on aircraft propellers and rotor blades, as in Take me off before spooling up!
-f
Ditto! In fifty years of formal training and shop experience, I have never even heard of relieving tension on blades.
thanks guys; i was just curious. regardless of the results to my question; i would have left the blade under tension
