- Apr 23, 2018
- 6,603
Jim, how do you accomplish a concave sweep with a vertically set tool? Do you use a cutter with a dog leg or offset?
The amazing thing is that you do NOT need any relief for a tool on center when turning a cylindrical piece of stock on the lathe. You only need it when facing. This is because the cylindrical side of the stock already falls away from the cutter and provides relief.how do you accomplish a concave sweep with a vertically set tool?
That answers my question perfectly. The tangentially oriented cutter is limited to outside radii, so another solution is needed for internal- and yours is just as simple as the tangential with the benefit of being able to make both types of cut.
Ah!He means concavity in the end.
Note, however, that you can also make (for lack of a better name) inverted fillets at the end of the part with a tangential tool (like if you were roughing out a piece of tool steel to make a rounding end mill).The tangentially oriented cutter is limited to outside radii,
In my conversation with Jim, he said he used another cylindrical cutter (broken end mill or whatever) but radiused and split as I mentioned above.Perhaps if you used something shaped like a boring bar
