- Jan 28, 2022
- 839
Hi, I think the easiest way to understand the tool is to visualize it in a vertical position and it is the same principle as the others. To control this style tool simply rotate the handle. I hope this helps you. Please read my reply to Weldingrod1 for my info. Thanks, CharlieI'm confused as to how this works to make a ball but looks like something I could build. Could you explain its operation to me?
Check rays build shows the operation around 11mmHi, I think the easiest way to understand the tool is to visualize it in a vertical position and it is the same principle as the others. To control this style tool simply rotate the handle. I hope this helps you. Please read my reply to Weldingrod1 for my info. Thanks, Charlie
