- Feb 24, 2015
- 1,382
I like using wire brushes on my bench grinders, but every one I've ever seen is out of balance, causing the bench grinder to vibrate. Some just a little, others so much that I fear they will damage the bearings on my grinders.
I'd like to get some suggestions and discussion on how to balance a wire grinder brush.
The first idea that comes to mind is to make a good fitting mandrel with an axle and set it between a couple of rails. It seems easy enough to find the heavy side, but how to go about adding or subtracting weight?
I suppose drilling a hole on the heavy side would be a method. Would you start with a small hole and increase its diameter gradually until it balances?
