- Mar 26, 2018
- 8,407
John,Cheap grinding wheels will also do that, due to out of balance.
What brand is good quality?
How much should I expect to pay for a good quality 7” x 1/2” wheel?
I tested all 4 of the hubs. All produce axial runout, that at the end of a 7" wheel is pretty big.That was my next thing to do. I just got 3 new hubs off ebay. And don't know if they run a "swash plate" wobble.
Thanks, that seems like a good approach to seeing what I have.@metric_taper
I suggest that, after you get the bearing off the fan end, you mount the shaft between centers and survey the whole thing.
I'm wondering if you'll be able to identify a bend or bow that might be corrected by "straightening".
What I mean by survey is to Sharpie some "clocking" marks (at least 4) on the largest OD and take indicator readings at intervals all along the shaft and armature. Record the readings in a table that shows not only the magnitude of the deviation, but also the clocking.
My point is that the whole rotating assembly should be dynamically balanced and having a "straight" assembly is a good start.
You mentioned that you were looking for 7206 bearings with shields on one side. If you're looking for individual bearings (not a matched pair), why not get them as the more common double shielded and remove a shield as required? YMMV.
Here is an eBay hub: Better runout, but still not good.I tested all 4 of the hubs. All produce axial runout, that at the end of a 7" wheel is pretty big.
This first video is of the one that came with the machine. Note the wobble to the nut that came with the machine, it's the threads on the spindle that appear to done with a hand held die, and the operator didn't do a good job keeping it square. At least that's what I think happened.
I worked with the original hub, and could get it down to 4 tenths. But that is not a solution I would ever consider. Everything needs to run true, as well the hubs.Now have you tried clocking the hub to different positions to see if you can reduce the runout?
