- Feb 2, 2013
- 3,638
i use the back gears on all my lathes, especially when threading and boring large holes in larger work.
Going on with the lube part of the thread .
Can anyone tell me what the thread form & TPI that there is on the USA's Atlas lathes that have screw down grease cups caps to lube the head stock taper roller bearings .
I ask because I want to replicate the thread on mine on a reasonable quality steel bar to make an extending shoulder so I can then drill and tap the extender shoulder for it to take a metric grease nipple .
This will be my first attempt at thread cutting on the lathe for the grease cup thread on the extender , I have a metric grease nipple tap for the other thread .
Perhaps you'd also be kind enough to explain the breakdown of how you write the thread form and size details plus give the thread angle as I don't have a USA thread gauge .
back gears = lower speeds without losing torque. Very useful for turning large objects (like chuck back plates) or perhaps work hardening steels where the surface speed would exceed what is recommended for the cutter. I wiped the nose off an HSS cutter in an instant truing up a 4in back plate at 800rpm - put it in back gear (100rpm for that pulley?) and it cut just fine. Also recommended for threading to a shoulder so that you have more time to open the half nuts before crashing the tool into the shoulder.
To be honest, if there's room and you have the skills/ tools I'd replace that screw with a knurled knob. You're supposed to oil the back gear pulley every time it's used and for me at least it would be way easier to have a tool free way of doing so.
Thanks Robert,
I kind of guessed that the Atlas lubrication system would be oiler pots through out as that's all that I've seen on the various video clips .
The reason I wanted to convert the cups & grease arrangement to a simple once a day small shot of grease out of a hand held small grease gun into the grease nipples is that I have sugar diabetes & it is affecting my finger sensations amongst other things. I can't always be sure I have hold of small things , so trying to put the grease filled brass cap back on the fine brass thread is difficult to say the least , on several occasions I've dropped them into the head stock casing . The cups on my lathe are set at an angle of about 15 degrees to the vertical facing outwards unlike the oilers which always appear on the videos to be in the vertical .
Are the Atlas Oilers a parallel thread or are they a taper thread ?
The threads in my taper roller bearing caps where the grease cups are fitted on my Sphere lathe appear to be fine parallel threads , not tapers as is usually found on old imperial British grease nipples of the 1940 's & 50's . Both the cups & the caps are made of brass.
After calling myself several delightful names and laughing at my own stupidity , I decided to have a look at the reason that the pin had engaged.
I rotated the pin ( discovered that last year when I got the lathe ) to take it out . So that the bearing & spring were compressed , then carefully slid the pin out as I covered the the top & inboard side holes with finger & thumb to retain both ball bearing and spring .
I found that the 1/4 inch dia locating pin has a half inch segment milled out the middle to a depth of about 1/8 of an inch . ( didn't think much about it last year when I took it out )
There are no grooved rings on the pin that would locate on the ball bearing under spring pressure so the pin cannot slide in or out at the slightest touch .
Is this milled out pin the correct one or has someone made their own pin and messed up , that it should indeed have two locating grooves on it instead?
