- Dec 25, 2011
- 10,511
If you didn't already do so (which you should have), remove the oil plug (looks like an Allen set screw) from the spindle cone pulley and squirt some SAE 20 oil into the hole to lubricate the pulley bushings. Reinstall the plug.
Then, with the back gears disengaged (normal position) but the direct drive pin pulled out, tighten the belt and start the motor. The pulley should spin quietly but the spindle should sit still. If it still makes the noise, find the source.
