- Aug 29, 2019
- 526
Long and short of the story. I have a Huanyang VFD hooked to a 2 hp 3 phase motor. It was working fine with the parameters I had in it. Start/Stop and FWD and REV and the pot for varying the frequency all worked fine. So today I attempted to install a remote toggle switch for the Start/Stop FWD/REV. Never did get it to work. I change the settings on P001-0 to P001-1 and got nothing. So, I pulled the wires off of the FWD and REV terminals and removed the center wire for the toggle switch from DCM Went back and changed P001-1 to P001-0. So now it starts and stops but I have Zero control with the Speed Pot. The P002-0 is at P002-0 as it should be for local control but when I start the motor it ramps up to full speed and turning the pot does nothing to control the RPM. I am semi-skilled at doing this because I put a Fugi Frenic-Mini on my mill and wired the remote toggle switch and remote pot and it works fine. So, before I go off the deep end, I am open for suggestions.
Thanks in Advance
Thanks in Advance
