- Mar 26, 2018
- 8,413
Hey all,
When I bought my surface grinder I went through it to make sure all oil lines weren't plugged, changed the filters, cleaned everything and replaced the 15 gallons of hydraulic fluid. This was in 2019. The manual says to change filters and oil every year. Now, I don't run this more than a couple times a month for less than an hour each event.
On the lubrication label they say to use one of the following;
Mobil Vaculine 1405
Sun Oil Co., Sun Lubeway #1405
Standard oil Co., Stanway #15H
The only original oil still available is the Mobil product. The best price I found was through PSC @ $161 for a 5 gallon drum. I need 15 gallons as I mentioned.
That puts this job at around $650 delivered.
Should I keep running the oil?
Should I do what the book says?
Is there a better/cheaper source?
Thanks,
Jeff
Mobil Vaculine 1405
Thanks,
Jeff
