- Oct 11, 2016
- 3,869
This style of grinder has the column moving back and forth, if it is truly like mine. I would then dismantle and check the ways. It sounds like something is on the Z ways causing it to lift. That is an early thing to check. Besides it is a very good thing to inspect the ways (without removing the column) Lots of info can be gotten from doing that. It might not get you to a direct situation, but you need to know their condition in any event.
I've had mine apart and aback together, and I decided that I needed to completely replace the lube system. I odered everything from "the leading company" - and they sent me parts incompatible with my pump and manifold. After that expensive disappointment, I shelved the project. Perhaps this summer...
