- Apr 12, 2011
- 3,472
$1450
Tell me, the factory in which this machine was apparently heavily used, with the really cheap maintanence department, replaced the precision, high radial loads capable bearings, with just a regular sealed bearing.
The bearing ran smooth until I put some oil in it and it loosened the grease, now it does a bit of clunking when spun. Is that a bad bearing disguised by grease or does the bearing require grease over oil?
I'd say the grease was hiding the bearing deficiencies and I'd replace the bearing.
Second, with the machine in the shape it's in, and it's just a home shop machine, is it worth putting that super expensive bearing in? Or will a good quality regular bearing suffice?
Only you can answer that question. Is it worth it to you? If you go the cheap route I'd think you'd be putting bearings in it all the time. Personally, I am one to make things right and would repair the machine properly. Good luck.
