AXA tool post disassembly
Triggerscan
Aug 27, 2014
10
First post here. I was thinking of making a nicer locking mechanism for my AXA tool post (250-111). Once you take the tool post off the mounting post, there is what appears to be a slotted locking nut that needs to be removed. Not sure if that's what it's called, nor what type of wrench one would use. A google search of spanner and bung wrenches yielded nothing. Does one use a pin wrench in the square slots? I tried "nudging" it with a screwdriver in case it wasn't in tight, but nope, firmly seated in place.
Yes, the slotted part must unscrew and come out from the top of the tool post. There isn't much to them. I wouldn't bother trying to find a slotted tool, instead just pull the whole thing off the stud and try a BFS (if you can have a BFH, couldn't you also have a big ol' screwdriver?).
Clamp the tool post in a vice after you remove the mounting bolt. Stick a piece of square key in the slot and loosen it with an adjustable wrench.
