- Nov 27, 2012
- 7,863
On my bandsaw blade that is. Actually it was a few teeth.
I normally use a 5-8 tpi blade most of time and switch back & forth to a 8-12 tpi. I really should have switched to my 10-14 tpi blade but I only had to make one cut on some steel plate. I've done this before cutting thin alumn & just ease into it by hand & use a slow feed on the feed cylinder. Wasn't so lucky this time. Now my 5-8 tpi blade has a bad lump while cutting. Ruined a perfectly good blade by being lazy! I hate to throw the blade away & keep thinking of ways to save it or use it for something else. Wish I had a tig welder & knew how to weld. Yeah yeah, I knew better & I hear about this all the time... "been there done that" from others but finally it happened to me. Lesson learned.
So just a reminder, don't be lazy!
