- Dec 25, 2011
- 10,515
First, access to DOWNLOADS requires current Donar status. Donations are good for one year. If several months ago, you were able to access Downloads successfully then the most likely occurrence is that your most recent donation took place more than a year ago, so you need to renew.
The 760 and the 6822 share all parts but three. The three parts are the two mounting brackets that attach to the bed plus the 6822 has two headed brass pins added. The two pins slide into the holes containing the two adjusting screws for the 10-764 draw bar and can be retrofitted to the 760.
If the larger 10-761 clamp is actually clearly marked "10-761", then you have a 760. Which fits the 3/8" bed lathes 9", 10" and early 12".
