- Dec 25, 2011
- 10,512
JP,
I did some research today, bought one M1-259 and acquired the factory drawings on the M1-258A and M1-258B. First, your M1-259 (the long bushing) has been either damaged or butchered. It should not have any groove in the ID. Second, I think that your other bushing may be an M1-258A (1/2" long) instead of the proper M1-258B (3/8" long). Neither bushing should need a clearance hole for the oil hole. Third, the original material is shown on the drawings as Oilite. But you still must oil the bushings about one a week if you are using back gear frequently or at least semi-annually if you aren't.
Sometime tonight, I will upload the drawings that I have. As soon as the M1-259 that I ordered arrives, I will upload a drawing of it. But you have one for getting the length of. The ID is supposed to be .876". The OD is 1.003".
The M1-259 that I bought from Clausing (along with two gears for the 30 second Metric conversion if I ever need them) cost $6.03. But I can't say that when they restock, the price won't change.
