- Dec 25, 2011
- 10,513
Greg,
Yes, the spindle nose threads are right-hand. But...
Do NOT try to remove the arbor from the spindle taper by unscrewing the arbor driver. It is keyed to the arbor by the two 1/4" pins and before it ever starts to push on the arbor longitudinally, it would have to rotate the arbor in the taper at least half a turn. If you ever did get the thing apart by using that method, you would have ruined the driver, arbor and spindle. The drill is that first you remove the arbor. Then you remove the arbor driver.
