- Nov 2, 2013
- 962
Now what to use to make it? Wikipedia says Zamak 3 is "the defacto standard" for Zamak alloys, and has a yield strength of 30,200 psi. The other Zamaks range from 29,000 to 52,000 psi. These seem pretty soft, so I'd guess it's Zamak 3. Again, Wikipedia says "T6 temper 6061 has ... yield strength of at least 35,000 psi (241 MPa). More typical values are ... 40,000 psi (275 MPa), respectively. Sounds like it's about right.View attachment 125642
I was with you with the drawing and the measures. But then the "T6" and PSI ratings .. you jumped way over my head!!! Help?
