- Dec 25, 2011
- 10,511
It has been a while since I last looked but I think that you will need to remove the headstock from the bed and invert both the bed and the headstock in order to take a decent photo of either casting number.
wa5cabThat's a nice looking restoration. And the spindle bearing journals look better than most. However, it is not a 10D. That would be an Atlas and a 10". And it would have the FWD-OFF-REV gearbox mounted to the bed in front of the headstock instead of the tumbler for that function.
It is either a late 101.07380 or an early 101.07381. And it must have shipped with the cast change gear cover because it has the cutout and tapped holes in the headstock for the motor switch and bezel.
We don't have any printed parts list for the 101.07380 and the one that we have for the 101.07381 shows the later legs and later tailstock. The catalog photo in the 1937 catalog shows the cast cover and early symmetrical legs but later tailstock. The 1936 catalog shows the sheet metal cover and the early tailstock that is cylindrical around the ram like yours. So what source document we have are inconclusive as far as which model to call it. I take it that the nameplate that should have been on the rear of the bed is missing.
To notify an intended recipient, use @wa5cab . (he will see this post so you needn't resend)wa5cab
Can you direct me as to finding and or purchasing a parts manual for a Atlas/Craftsman lathe with a ID #101.07381. Any help would be appreciated.
Thank You
Thomas
