- Dec 25, 2011
- 10,525
I would agree with you about the key and keyway. But on the other hand, in the 40+ years that I have had my 3996, the larger pulley has never moved on the shaft. Which is not true of the motor pulley. I used to have to loosen the set screw and slide it back onto the motor shaft at least once a month. I finally bought a split collar from Mcmaster, repositioned the pulley on the motor shaft, and installed the collar on the shaft up hard against the pulley. Since I did that, the pulley has never moved again. I probably did that 5 or 6 years ago. So I think that I would recommend leaving the larger pulley as is.
