- Dec 25, 2011
- 10,513
I would keep the motor switch that's mounted on the headstock and use it to start and stop the motor. Mount the drum switch somewhere behind the lathe, out of reach of kids and knob twiddlers. I have never heard of a case where a properly seated chuck came loose just from starting the motor in reverse. However, do not do any turning, threading or facing in reverse. But grinding in reverse is normal and OK. You don't want the grinding wheel throwing the spark stream up in front of you. And you don't want the spindle running in forward with the stream directed downwards because that subtracts the wheel speed from the spindle speed and reduces the relative velocity of the wheel and workpiece.
