Atlas 9” lathe Babbitt bearing caps reversed
Mike, does your lathe include the large-diameter spoked pulley shown in the photo below (the one at the top)? If it does, would you mind sharing the diameter? My lathe is missing this pulley and I want to see what my options are (looks like there are plenty of aftermarket pulleys available). Thanks in advance!
P.S. Last-minute addition :) : looks like I don't have the small motor pulley that the large one is connected to (the one in the bottom left corner of the photo) either, so the diameter of that one would be much appreciated as well.
xyz07,
The 9" Atlas lathe used a single sheave pulley. 9-3/8” outside diameter, 3/4” shaft size, 5/8” width. The one I have is in very decent shape. If you’re interested pm me. I'm not sure on the motor pulley. However, the motor pulley on my 10” lathe is 2” and that is perfect for what I need. I only use the larger diameter (9-3/8”) countershaft pulley. ymmv
9 Inch Pulley 1 .JPG9 Inch Pulley 6 .JPG9 Inch Pulley 3 .JPG9 Inch Pulley 2 .JPG
Mike
