- Jan 29, 2017
- 26
Lots of good help, thanks folks!
I wouldn't generally need to turn anything large diameter so a 6" is more than adequate. Length wise I would love to be able to fit at the largest bass clarinet body sections.
Honestly a whole lot of the work is spinning small diameter steel rod, straightening rods, threads, making simple tools on the spot out of steel and brass, holding clarinet sections for tenon work, making sockets for saxophones (turning small diameter brass), etc. Basically its opening up my world of possibilities quite a bit from having just a bench motor.
Also, the argument I'm having in my brain is small Taig/Grizzly style lathe to learn on, then getting something bigger (because these do present limitations in length) vs. investing in a machine like this Atlas that can potentially do it all.
Thanks again,
Mk
Thanks again,
Mk
