    Dismiss Notice
Atlas 10F-28 purchase questions?
Discussion in 'ATLAS, CRAFTSMAN & AA' started by unioncreek, Jul 31, 2017.
  1. wa5cab
    wa5cab Downloads Moderator Staff Member H-M Supporter-Premium
    677
    113
    Spring Branch (Houston)
    City:
    Houston
    State:
    Texas
    -Return to Top-
    The miter gear that runs on the lead screw was original cast with a square key in it's bore. This key has been variously reported as either worn off or sheared off. One of the ways that have been proposed or tried was to bore out the remnants of the old key, drill a row of holes, and insert a row of pins. The downside of doing it this way is twofold. First, until the pins wear s little bit, the surface area of the pins actually in contact with the side of the lead screw groove is only a line. So you would expect rapid initial wear. Second, the protrusion of the pins into the bore of the gear is rather critical. As much of the pin as possible should be in the groove. But it is critical that the pin not touch the bottom of the groove.So I couldn't recommend this method.
  2. unioncreek
    unioncreek United States Active User Active Member
    11
    18
    City:
    Colfax
    State:
    Washington
    -Return to Top-
    I agree on the use of pins. I'll probably think on it a while before deciding how to go about it. The power cross feed is not necessary right now, so I'm in no hurry to come up with a solution.
    Bob
  3. rzbill
    rzbill United States The cheapest thing in an airplane is the pilot. Active Member
    73
    18
    City:
    Leicester
    State:
    North Carolina
    -Return to Top-
    I just bought that gear a few weeks ago so i could have a replacement to use while doing a home repair on the one currently in the lathe. (It still has a sliver of key left). It was pricey but the transaction was so easy with Clausing I thought it was worth it. Memory is a little dim since I ordered a few other gears too but around 100 bucks I think.
Share This Page
