- Dec 25, 2011
- 10,513
Well, some of the items on your list probably have a lower than $100 average used price. And I would probably only count one of anything on the list that there is more than one of. And don't count anything that you don't think you will ever use unless you think that you can fairly easily re-sell it. But that is the only way to fairly compare this offering to any other. Including new.
Also, I meant to mention earlier that one of the tailstock chucks has the correct type of arbor and another one still has the tang on it. If that happens to be the chuck that you want to use in the tailstock, I would cut the tang off and grind it flat to match the length of the tang-less one. You will gain about 3/8" of usable ram travel. Otherwise, only use the tanged one in the drill press. And/or re-sell it.
