- Dec 25, 2011
- 10,513
The 5" chuck that you have probably was bought from Atlas with the lathe. If it is like the 6" Union chuck that came with my Atlas 3996, it does not have a backing plate. The rear of the chuck body is threaded 1-1/2"-8. If you found the #2 and #3 inside jaws, the #1 is probably there somewhere. If not at your house, it would be worth a trip back to where you bought the lathe to look for that one jaw.
If all that you wanted to do with a collet set was to hold milling cutters, the least expensive choice would be a full set of 3MT and a 3/8"-16 draw bar. These would directly fit the spindle nose taper. However, if what you want to do is hold 3/4" or smaller work, the 3MT wouldn't be a good choice as they only come in 1/16" increments and you can't pass the work through them because of the draw bar and 3MT arbor. I have a 3MT set, a 3AT set and a 5C set, the latter two of which can pass stock or work through the spindle. However, the last two would be pretty expensive to acquire a full set of today. I would suggest either ER25 or ER32, and only with a 1-1/2"-8 threaded collet chuck so that you can pass stock through the spindle. But do not buy a collet chuck with either straight shank or 3MT mount. Neither of these types will allow you to pass work through the spindle. Plus the 3MT requires a draw bar to be safe and the straight shank requires a 3-jaw or a 4-jaw chuck to hold it. Otherwise, the only drawback to the ER collets with threaded chuck is that of all of the types of collets, they are the slowest to load and unload. However, unless you have a job to make a bunch of parts, that isn't a major problem.
