- Jan 31, 2016
- 11,461
Yep . Ok , so I know where the surface grinder is that could do it . The price will be the decision maker . It needs a gib and it's wired 440 , so there is money . I may just part it out !
It is excellent stuff, but too prone to impact damage to leave exposed. It is good in the cross slide, compound slide, and the under side of the carriage and tail stock, but not so much for the top of exposed ways. It is a type of epoxy resin with metal additives, there are many varieties with different properties. It needs to be "cast" in place after getting all the oil out of the metal surfaces and then roughing the surfaces up, then casting it in place on to the surface. After it is dry, it is scraped to the correct thickness and fit. I have not worked with it, but do have some experience with Turcite (Rulon), which comes in sheets ready to cut to size, epoxy in place, and scrape to fit. Scraping it is fast, as it is soft (but tough). All of it is expen$ive, but often worth it to get the job done when you are running out of metal thickness to make things fit together. Once installed and fit properly, these products stay good for a long time with normal and proper care. All need to be precision scraped for machinery sliding surfaces.I've never used this stuff but have heard its an excellent product
http://moglice.com/moglice.html
