- Aug 29, 2019
- 510
I have the original X axis power feed working that came off of my Bridgeport Clone Mill. It looks just like the generic power feed units marketed by Align and Vevor. My issue is that the model plate says the unit is for 220/240-volt ac. I am not comfortable plugging it into 220 volts because it has a standard 110-volt 3 prong plug, I have ran it on 110 volts and so far I see no problems with it. This unit (Mill) came from Mexico. and it looks like someone has replaced the power cord. What is worst case if I continue to run it on 110 volts and is there anything recognizable about the PC board that would tell me I should run it on 220 volts? Other than me being nervous it seems to be working as it should. TIA
